Could be the carb just needs a rebuild, but also check the fuel flow to the carb and make sure there is a good clean flow of fuel to the carb. There is a fuel filter screen on the carb, make sure it is clean. If you have a in-line fuel filter, remove it. The carb is pretty easy to rebuild, if you purchased a kit, it should include instructions. The venturi in the F-20 carb needs to be put in a certain way, there is a notch in it that needs to line up with another notch in the carb. Instructions should say it all, but post here if you have any more questions. I see your block is repaired, did you use JB weld? How long is the crack? My F-20 has a cracked block too, I put on JB weld for now. The crack in my F-20's block is very long, the crack goes all the way onto the water pipe mounting surface, not good, but it seems to hold the coolant.
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
