Posted by Janicholson on November 12, 2008 at 19:07:12 from (66.173.50.128):
In Reply to: For donald schnupper posted by Dr. Bert on November 12, 2008 at 18:52:08:
Many manifolds are prone to cracks and self destruct. Even modern auto engines have issues with the manifolds. Extreme heat (near 1200 degrees) and then cooling to ambient summer temps, or below freezing in winter then repeating that thousands of times. External cracks and holes (rustout) is most common. Internal between the intake plenum, and exhaust heat transfer section (especially dual fuel manifolds) is next, and difficult to find. Yours probably does not have an internal crack, if it was loose. Checking well requires taking it off, and plugging the exhaust pipe hole and filling it with water while on its back and the ports are up. This will show leaks internal to the intake. Some exhaust manifolds have intentional holes designed to let water out befor it does damage. These are less than 1/8th" or so and can be plugged to check for cracks, then unplugged for operation. Jim
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
