Re: M steering problem
Posted by Dardo on November 13, 2008 at 11:32:13 from (12.216.190.9):
In Reply to: Re: M steering problem posted by Bob M on November 12, 2008 at 08:25:39:
IT WORKED!!!! Just like you said it would. Thank you so much. I would have never gotten that gear off without your help. The bearing at the bottom was shot. It came out in pieces and rusted balls rolled all over the shop. I suspect that may have been contributing to the wobble. Now, I need more help. After tearing it all apart I noticed that one of the bolts that holds on the front wheels has an extra tall head. I assume that is some sort of stop to keep the wheels from spinning all the way around? Problem is I did not notice which postion it was in, front or back right or left. When I get all the parts and put this all back together, where do you think I should put the tall headed bolt?
