Posted by El Toro on November 13, 2008 at 16:15:51 from (205.188.116.73):
In Reply to: grandpa's farmall a posted by sunaewayha on November 13, 2008 at 15:19:34:
Pull the head and pan and soak the pistons with ATF. That engine has wet sleeves and if you remove one the rod caps you can tap on that rod with a piece of 2 X 2 oak and a good hammer to see if the piston will move or if the sleeve is starting to move. Once the sleeve is out you can a torch to heat the sleeve to free the piston. The rods can probably be reused. I would install a new sleeve kit. That block area needs to be cleaned where the sleeve seals are installed. New seals will come in the sleeve kit. Need to be patient too and take your time. Hal
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
