Re: electrical problem help
Posted by Allan In NE on November 14, 2008 at 02:09:22 from (148.78.243.24):
In Reply to: electrical problem help posted by Gary Sedlacek on November 13, 2008 at 18:50:30:
Gary,
Sounds like you are using a test light to trace the power?
Electricity follows the path of least resistance. In this case, that path would be thru the starter instead of your test light. This is normal.
If the starter is spinning and not engaging, you have a mechanical problem with either the starter drive or the engine flywheel.
Ms don't have solenoids. That's another bird entirely.
Alla
