Re: grandpa's farmall a
Posted by Gene Bender on November 14, 2008 at 08:40:21 from (67.55.226.167):
In Reply to: grandpa's farmall a posted by sunaewayha on November 13, 2008 at 15:19:34:
Pull the head and check the cycls cause there is a reason its stuck. You probably will find them all rusted up therefore are junk. Press the sleeve and piston out as they use a wet sleeve and you can have new sleeves pistons rings and so forth for around 300 just check prices you dont need another block. You can remove the sparkplugs and with a good lite see the condition of the walls
