Re: Farmall Super C head bolt torque specs?
Posted by John_PA on November 14, 2008 at 09:00:54 from (72.95.153.230):
In Reply to: Farmall Super C head bolt torque specs? posted by John_PA on November 14, 2008 at 08:29:56:
Dave,
Thanks for the info.
The tractor is a Farmall C according to the serial number, it would be a 1950. Going by casting dates(which are all "T" year code, which I assume is 1950, the engine casting date is X, which would make the engine a 1954. I would say that since the engine has 1954 casting dates, and step topped pistons and a 3.250" bore, I would say that it is a super C engine. However, the previous owner had replaced the cylinder head, and he didn't know that the block was not original to the tractor, and he could have installed a Farmall C head, and used the farmall C waterneck. So, I could have a farmall C waterneck and cylinder head. If so, where does the thermostat go?
Thanks,
John
