Posted by Dellbertt on November 14, 2008 at 15:36:46 from (209.172.21.127):
In Reply to: #@$%*##$ charging system posted by Gerritt in michigan on November 14, 2008 at 10:27:34:
I"d be curious to know if the gauge indicates zero volts with the engine off then shows negative charge after start and varys with RPM. If it does then just switch the pos and neg ternimals and see what happens. If it shows pos or neg with the engine off then you have a short or incorrect wiring.
There is lots more theory knowledge in here than what I have, but I like to first run test the gen to make sure it is giving off a charge and then work backwords.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
