Re: #@$%*##$ charging system
Posted by john *.?-!.* cub owner on November 14, 2008 at 21:04:37 from (75.120.255.175):
In Reply to: #@$%*##$ charging system posted by 686142 on November 14, 2008 at 10:27:34:
Owen Aaland said: (quoted from post at 14:00:02 11/14/08) Cut out switches will never have a terminal for the field control wire. The field control wire goes to the light switch where it is grounded through the resistor in the low charge position and direct to ground in the high charge or lights on positions. In this system it is necessary to have a good ground path from the light switch all the way to the battery.
actually the originals do have an Field terminal. It has a resister to ground to complete the field circuit in applications where there was no lights, therefore no light switch, but needed to charge battery for the starter. The field terminal is not normally used, however, since that particular application is rare. If the light switch field resister is burned out you can run a second wire to the F terminal on the cutout to provide the low charge function.
Today's Featured Article - The Fordson F Ignition System - by Anthony West. A fellow restorer contacted me earlier this year asking for some help and advice on a model F that he was restoring. He had over a period of months spent a fair amount of his hard earned cash on replacement parts for the old "trembler" ignition. Sadly though all his efforts seemed to be a waste of time and money as he still couldn''t get the temperamental old thing to run correctly!! If i said that this was a little frustrating for him that would be "conservative" in fact the problem had reduce ... [Read Article]
