Re: #@$%*##$ charging system
Posted by Gene Bender on November 15, 2008 at 02:28:18 from (67.55.226.167):
In Reply to: #@$%*##$ charging system posted by Gerritt in michigan on November 14, 2008 at 10:27:34:
You need to have ground on the generator and also the reg and also the lite sw. Use an Ohm meter to see that all the componets are grounded. System is positive ground. Check your regulator underneath and it should say which ground the regulator needs if you do have a reg and not a fastory cut-out. The factory cut-outs are no longer available or at least i have not been able to find one as they were built by Delco Remy. I have 6 Bs and As that still are original and work just fine.
