Re: cracked manifold on m
Posted by James Rumph on November 15, 2008 at 06:08:20 from (24.192.125.175):
In Reply to: cracked manifold on m posted by donald schnupper on November 14, 2008 at 18:00:49:
If it's just a hole drill and tap that spot for a pipe plug.
"Brazing will not melt off the manifold", the melting point of your alumnium pistons is lower then that of brazing rod.
To braze a crack you first drill a small hole at the end of the crack to stop it from spreading.
The best way to do this is to then put the manifold in a oven and bring the hole piece up to the same temp, then braze or weld it.
Any good welding shop will do this. If you don't want to put it in the kitchen oven then warm the hole piece with a rose bud nice and slow.
Brazing will last a long time.
