Re: piston stuck in sleeve
Posted by hicksdale on November 15, 2008 at 11:11:22 from (74.36.247.188):
In Reply to: piston stuck in sleeve posted by TLT on November 15, 2008 at 06:57:25:
Remove the oil pan, get as many connecting rods loose as you can, use a hydraulic jack to push the piston and the sleeve out of the block. If you can do that, then remove the piston from the sleeve by cutting the sleeve from top to bottom with a metal cutting wheel on an angle grinder. That will let you split the sleeve enough to get the piston out.
I have also removed all the tin work, the head, the pan, (all that I can get apart), put diesel into the cylinders, and set it fire (outside). This heats the block slowly and uniformly and sometimes this will break the piston loose in the sleeve, with some pounding with a wood block or a jack from the bottom.
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
