DEo not run it that way! There is a seal in the hydraulic pump which can go out causing a massive "filling" of the oil pan. This is not engine oil, and must be repaired. The seal will be easy to get at, but could be either a lip type seal, or an O ring. If the shaft has a groove in it (any) it will need to be repaired with a "Speedy Sleeve" This is a thin sheet metal tube that is placed over the worn shaft. (NAPA and others have them) If it is a O ring style, the housing may need to be opened up a tiny bit to allow the sleeve to fit inside the location of the O ring. It is a machine shop type of repair if that is needed. If the bushings in the pump are worn and allow any play, the pump is probably toast. JimN
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
