Re: 200 not firing
Posted by Janicholson on November 15, 2008 at 13:52:27 from (66.173.50.167):
In Reply to: Re: 200 not firing posted by LMack on November 15, 2008 at 13:42:03:
If you take the wire off of the distributor side of the coil, put a jumper lead on it, put a condenser on the other end of the jumper with its case grounded to the block (maybe another jumper), then touch the connection with the condenser lead in it to the ground and then pull it away, you will mimic a set of points. If the coil fires, it is fine. If it does not it may be bad. JimN
Today's Featured Article - When Push Comes to Shove - by Dave Patterson. When I was a “kid” (still am to a deree) about two I guess, my parents couldn’t find me one day. They were horrified (we lived by the railroad), my mother thought the worst: "He’s been run over by a train, he’s gone forever!" Where did they find me? Perched up on the seat of the tractor. I’d probably plowed about 3000 acres (in my head anyway) by the time they found me. This is where my love for tractors started and has only gotten worse in my tender 50 yrs on this “green planet”. I’m par ... [Read Article]
