I know you said you cleaned things up. Anything that runs to that switch that needs grounding grounds through the switch body and therefore the box and anything connecting the box to the chassis. Have you got all those connections (like the nut holding the switch to the box . . .) clean. If that wire from F up front back to the resistor can't find a good ground through the switch, she won't charge hard.
That said, you did say you ran the wire from the field straight to the battery + post, so it may not be related, but is worth a look and a try.
Have you been through any of John T's checklist yet?
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
