Re: M
Posted by Janicholson on November 16, 2008 at 05:48:01 from (66.173.50.135):
In Reply to: M posted by jd9295 on November 16, 2008 at 04:23:07:
Armand is correct, the inline filter is restrictive and designed for fuel pump use, not the micro pressure of gravity feed. Though it would seem to pass air well, it does not pass fuel much. that being said, there are fuel filters from NAPA and others that are specific to gravity systems. They are great, but the best is the sediment bowl that is OEM, along with--- By Clean Fuel Keep it Clean--
that is stamped on the old style caps.
That may still not fix your carb. Is the screen at the carb inlet clean? Is the float hanging up on the side of the bowl holding the needle closed?
Is every passage actually open to flow. These are also likely issues. Even a loose or leaky intake manifold, or one with a hole through the inside to allow exhaust into the intake is a possible contributor. Good luck, check it out and let us know. JimN
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
