Re: Brake Pedal Shaft
Posted by CNKS on November 16, 2008 at 09:15:58 from (216.144.104.128):
In Reply to: Re: Brake Pedal Shaft posted by David Goode on November 16, 2008 at 05:53:47:
I think the check level plug on the left side of trans housing is slightly below the holes for the shaft, drain it to that level if it is overfull.
