Re: Super C cut ou/regutalor
Posted by JanicholsonCant beat that on November 16, 2008 at 11:52:39 from (66.173.50.53):
In Reply to: Super C cut ou/regutalor posted by ff in mi on November 16, 2008 at 11:37:57:
I believe all Super Cs had regulators. If it has a three position light switch, it will have a regulator. ODB Off Dim Bright. If it has a 4 position light switch (it should not) it will be LHDB Low charge high charge Dim Bright.
That is used on all Farmalls with a cutout. (except those that originally had no light system from the factory as an optional delete) they had a three terminal cutout with a low charge resistor for the generator for starting purposes.
Because you state it is converted, it might have an alternator in which case it probably has a built in regulator in the case of the alternator.
If it is a generator system, it could have a cutout, but unlikely. If it has a little box connected to the generator, and that little box has two terminals only and it has the 4 position light switch, it is cutout. JimN
