Re: Farmall 450 power sterring not working
Posted by trulyred on November 16, 2008 at 15:54:15 from (216.252.3.187):
In Reply to: Farmall 450 power sterring not working posted by neal'36 on November 16, 2008 at 06:18:44:
There is a button plug with an o-ring on it located between the first stack valve and the steering post. All three valves are bolted together with long studs and nuts on the outside (right) end. You will have to take all the stack valves off to get to the plug or at least be able to slide them far enough away to work between the post and the first valve. I had one once that just wouldn"t stay in place so I ran a 5/16 or 3/8 threaded rod into the port from the end cap long enough that the end cap held the plug in place.
