Re: f-14 wide front dual fuel
Posted by thurteauf14 on November 16, 2008 at 16:14:02 from (205.188.116.73):
In Reply to: f-14 wide front dual fuel posted by thurteauf14 on November 16, 2008 at 15:44:23:
Also what would the value of this be?I know it is hard to say without seeing.Has belt pulley,shutters that are mint as well as the manifold ,no rust anywere,was repainted around 15 years ago,small tank on the hood is missing the filler neck ,no cracks or welds on block or any other place.It does give a kick when you crank but I think the impulse is not working.Have it in the garage with the oils dranning,did find gas in the oil so I'll have to rebuild the pump but other than that it ran just as smooth at could be. Tom
