Re: Leaking Hyd Control Valve- Going Nuts!
Posted by caterpillar guy on November 16, 2008 at 16:20:15 from (64.12.116.73):
In Reply to: Leaking Hyd Control Valve- Going Nuts! posted by Jim Allen on November 16, 2008 at 07:57:50:
If it is just the equipment saging it could be the cylinder is leaking by the piston and not the valve.
Check for any burrs on edges of the bore or valve shaft. It could be just the spool and body are worn enough that it is valve time.
