Re: Could my M run a big round baler?
Posted by CenTexFarmall on November 16, 2008 at 18:48:56 from (172.130.208.219):
In Reply to: Could my M run a big round baler? posted by zooeyhall on November 16, 2008 at 17:31:10:
You absolutely can run a round baler with a plain M!
I've done it successfully with a '50 M that had typical wear for its age. It did it, but I must say that it was all it wanted when the bale got to be full size. If your M has a fresher engine it will do just fine.
I wasn't using the biggest round baler, but the bales I made were in the 800-1000lb range. You can experiment with the size and tie the bales off at less than full size if you need to.
You can use the liftall hydraulics but you'll need to do a little plumbing to work with the two way cylinders on the baler. Do a search for posts on setting up for two-way cylinders and you'll find good info better than I can describe here.
You'll have to use a little strategy when baling; give yourself about a tractor space before you enter the winrow to get everything rolling and the engine stable at speed. When the bale is about done you can let the baler drift out of the windrow as you are tieing the bale off so that you can be out of the hay when you make the final wraps of twine, 'cause as soon as you hit the clutch everything stops!
Today's Featured Article - History of the Cockshutt Tractor - by Danny Bowes (Dsl). The son of a very successful Toronto and Brantford, Ontario merchant, and himself quite an entreprenuer, James G. Cockshutt opened a business called the Brantford Plow Works in 1877. In 1882, the business was incorporated to become the Cockshutt Plow Company. Along with quality built equipment, expedious demand and expansion made Cockshutt Plow Works the leader in the tillage tools sector of the farm equipment industry by the 1920's. ... [Read Article]
