Re: OT: PICTURES of Root Rake, Ridgid Harrow I built...
Posted by billde on November 16, 2008 at 19:12:06 from (72.26.91.191):
In Reply to: OT: PICTURES of Root Rake, Ridgid Harrow I built... posted by charles todd on November 16, 2008 at 18:54:15:
Been there done a lot of that. You have very little distance between the rear wheels and the first set of teeth. Your rake will fill quickly.
Best results we ever had was to use a root rake on the dozer followed by a harrowgator. You need a harrowgator with a high lift. Unless it is bone dry your tooth spacing is going to pick up a lot of dirt.
