Re: Could my M run a big round baler?
Posted by Smith1000 on November 16, 2008 at 19:39:12 from (12.213.112.58):
In Reply to: Could my M run a big round baler? posted by zooeyhall on November 16, 2008 at 17:31:10:
I use a round baler behind a Super M. The baler will make 5X5 bales and calls for about 50 HP at the PTO. I do not make the bales full size. The baler will make bales up to around 1,000 lbs. Even at 3/4 size, it is quite a load for the tractor. I usually make the bales between 600 and 700 lbs. Would like to find a 4X5 baler for it that runs off about 40 H.P. This would be a better set up.
