Re: 6volt starter on 12v conversion
Posted by Buzzman72 on November 16, 2008 at 20:56:24 from (74.129.220.44):
In Reply to: 6volt starter on 12v conversion posted by e-manhunt on November 16, 2008 at 19:33:08:
I agree with the other guys here. If you have to crank the 6V starter long enough to burn it up when you convert to 12V, you've got other problems that deserve attention...points, plugs, coil, carburetion, or bad bushings causing binding in the starter itself. But most of the 12V conversions I've seen have had zero problems with the starter.
