Re: head gasket sealant ...opinions please
Posted by george md on November 16, 2008 at 21:55:49 from (209.213.167.210):
In Reply to: head gasket sealant ...opinions please posted by sgtbull on November 16, 2008 at 19:58:48:
sgt,
It would appear that there is an imperfection
in either the block or head.Most modern gaskets
have a chemical coating on them and say on the
box or on the gasket " use no sealer".
If you had the head cut on a van norman rotory
broach or a storm vulcan blockmaster , the odds
of you getting a good surface are not good. If
you had the head surface ground or cut on a
machine that uses a cbn or pcd cutting tool and
runs at the speed of the surface grinder , you
will get a perfect finish.
If the surface on the head has cutter marks
that you can feel,it will probably leak.
george
