Re: 340 t.a. HELP
Posted by JanicholsonCant beat that on November 17, 2008 at 15:24:53 from (66.173.50.80):
In Reply to: 340 t.a. HELP posted by Mark W. on November 17, 2008 at 06:20:54:
If the TA clutch wears out, it will not allow direct drive. THe TA clutch "locks up the planetary gearset in the TA making it drive direct. When it slips, it allows the Gears to reduce the ratio, and the one way Ramp/Rollers clutch keeps the TA assembly from turning backwards. It is somewhat uncommon, but is easily repaired (with a split). I would replace the one way clutch and the TA clutch, and the master clutch/Throwout bearing while I was in there. JimN
