Well you can just change the pinion, but it will make one heck of a racket. So if your changeing the pinion you should change the ring gear with it cause each ring and pinion are made as a matched set.
As far as the axle pulling yes. You just need to remove the bearing/seal retainer on the end of the axle, and remove the bolt holding the bull gear to the axle and you can pull the axle out. You kind of have to wobble the axle to get the gear to slide off. It helps to have another set of hands, or use shims to hold the bull gear up so it doesnt drop to the bottom of the transmission case.
The photo is a 560 axle but it works the same for an H.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
