806 Hydraulics....
Posted by Dan Swanson on November 17, 2008 at 19:35:54 from (63.172.252.161):
Bought an 806 that has a single set of hydraulic couplers at the rear of the tractor. It has dual levers in the cab. It has a set of couplings coming out on both sides of the colmun right behind the fuel tank. The rear set are controlled by the inside lever in the cab. How do the two sets behind the fuel tank come into play? I need to get a second set of hydrulics couplers at the rear of the tractor. Are the ones behind the tank are controlled by the second lever? If so, can I extend the lines to the rear of the tractor and use them? If not what do I need to do to get another set to the rear of the tractor?
Thanks, Dan
