Farmall Tractors Discussion Board
Re: Farmall M - 12 V conversion
Posted by mel whiting on December 22, 1998 at 18:42:56:
In Reply to: Farmall M - 12 V conversion posted by Brent on December 22, 1998 at 11:31:21:
to install a tank heater i plumb out of the block drain, around the back of the engine and connect into the hole where the temp sending unit is pluged into. you need a pipe tee and a short nipple to reconnect both the temp sending unit and the heater hose. I place the tank heater on the bell housing near the starter. this system works well. good luck.
Post a Followup
: Re: Re: Farmall M - 12 V conversion
