Re: MD wont switch to diesel
Posted by Janicholson on November 17, 2008 at 20:31:42 from (66.173.50.12):
In Reply to: MD wont switch to diesel posted by bigdiesel on November 17, 2008 at 17:56:55:
It must be operated at least 1.5 to 2 minutes on gas before switching. It is necessary to have solid Diesel compression to make it ignite, so if it will not, it may be any factor reducing compression, as Chuck's repair indicates, it could be misadjusted starting valves, or stuck starting valves, or bad/stuck rings or bad main valve adjustment (less likely). If it does pump air out the spark plug holes on diesel mode, after checking full motion of the linkages to the head, pull the Valve cover and see if the third valves are sticking open. Tapping them with a plastic hammer, squirting with PB Blaster, and repeated tapping may free them W/O head removal. JimN
