Re: Farmall H - Radiator Removal
Posted by glennster on November 18, 2008 at 10:19:17 from (76.222.60.2):
In Reply to: Farmall H - Radiator Removal posted by ezed76527 on November 18, 2008 at 08:50:16:
you prolly dont have the dust cover on the tractor. its a piece of tin a little under a foot square, it was there to keep mud from getting thrown up into the lower bolster.not sure if you have an i-h wide front or an aftermarket on your h, but there are two holes in the bottom of the lower bolsterjust below the rad mounting studs that you can get a deep socket up on the hold down nuts. first tho....spray the studs and nuts up good with pb blaster penetrating oil and let em soak up. there may be a cotter pin and castle nut with a spring holding the rad down, unless someone was in there before. there is also a hole in the lower bolster just below the crank start unit, , not a lot of room, but it is possible to get a box end rachet up in there to get the nuts off. at the very worst, you need to jack up the front of the tractor, block it good, then loosen and lower the wide front mount brackets on the bolster steering shaft to get to the studs.
