Re: 450-m
Posted by 460anger on November 18, 2008 at 16:50:40 from (65.110.104.19):
In Reply to: 450-m posted by how much work is it on November 18, 2008 at 16:33:40:
ben done a 1000 times you need a transmission cover from a super mta that way you have all the bolt holes to mount your steering post, battey box,and if you want live hyd, you will also need the control box hyd reservior from a super seires wich you can use from your super m to make it look right you should also change the clutch pedal the 450 is the same as far as working but they are differnt at the top.dead give away super mta is all bye itself but then if you no your casting codes thats a give away to. but as long as your doing it for the fun of it. then have at it!!!!
