Posted by RustyFarmall on November 19, 2008 at 08:23:44 from (209.152.78.71):
In Reply to: Re: Block heater posted by Dellbertt on November 19, 2008 at 05:54:10:
Delbertt, I really can't answer that question. I've never used one of those magnetic heaters.
If the engine has accessible frost plugs, a frost plug heater is the best way to go.
If there are no frost plugs, a tank type heater will be just fine. You plumb it into the engine block coolant drain hole on the left side of the engine, and then TEE into the cylinder head where the temperature guage sending unit is located. The cooler water is drawn out of the block drain, heated by the tank heater, and since WARM WATER rises, the coolant is returned to the engine through the temp. guage sending unit port in the head.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
