Re: Farmall A H4 Magneto problem
Posted by J in Pa on November 19, 2008 at 09:13:32 from (24.239.59.159):
In Reply to: Farmall A H4 Magneto problem posted by winds1sj on November 19, 2008 at 08:43:02:
howdee.
how bout the impluse spring? sometimes they get weak or broken. or the pawl springs. happens to them also.
when turning the mag coupling, there should be a good bit of resistance before the impluse trips.
good luck with it.
J in Pa
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
