Re: Farmall H will not run
Posted by Randy in NE on November 19, 2008 at 12:23:25 from (204.124.193.192):
In Reply to: Farmall H will not run posted by Mike - PA on November 19, 2008 at 12:14:34:
Have you checked fuel flow to the carb? If you disconnect the gas line going into the carb you should get a solid stream from the gas line. If not, check the screen into the settling bowl. Make sure that the screen is clean and that the settling bowl is not full of water. If you have good flow to the carb then it sounds like a carb adjustment issue. Is the float set right and does it work, no pin hole leak or anything? Are the internal passages clear? Have you set the adjusting screws external to the carb? Others will jump in here with other ideas.
