Re: Farmall H will not run
Posted by ScottyHOMEy on November 19, 2008 at 12:24:05 from (71.241.193.150):
In Reply to: Farmall H will not run posted by Mike - PA on November 19, 2008 at 12:14:34:
Can you spray gas/carbcleaner etc. at other points and get it to pick up? If so, that would suggest a vacuum leak at either the carb or head end of the manifold?
If not, restricted fuel flow (crud, stuck float needle . . .) is more likely.
