Re: Farmall H will not run
Posted by RustyFarmall on November 19, 2008 at 12:25:54 from (209.152.78.71):
In Reply to: Farmall H will not run posted by Mike - PA on November 19, 2008 at 12:14:34:
Did you have the fuel inlet fitting out? Is that cylinder shaped screen clean? Do you have full fuel flow to the carb from the tank? There is also a fine mesh screen in the top of the sediment bowl. Also, don't overlook the possibility of rust, crud, or some other foreign object in the tank that is restricting fuel flow.
