Re: Block heater
Posted by JimB2 on November 19, 2008 at 14:10:46 from (99.241.179.24):
In Reply to: Block heater posted by AJ Clark on November 18, 2008 at 19:44:03:
HI AJ, I assume your 354 has a BD154 Diesel engine. From 1962 thru 1991 we had a series of B414,434,384 tractors all with BD154 Diesel engines and front end loaders on them and they were used every day in the winter to feed silage. The B414 and 434 had inline heaters in the lower rad hose. We had no problems with the heater in winter or summer. Plugged heater in for 30 to 45 minutes in the coldest days and it would start everytime. The 384 had a tank heater like El Toro's picture. It was Dealer installed but it is a PITA to install on BD154 as the only top end outlet is the thermostat bypass on water pump and lower end is drain plug just above starter. The tank heater would warm the engine slightly faster on really cold days. We live in Eastern Ontario so in the 1960s we did see temps as low as -35F for a week at a time.
My recollections
JimB
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
