Re: Farmall H will not run
Posted by Mikes - PA on November 19, 2008 at 17:37:15 from (205.188.116.73):
In Reply to: Farmall H will not run posted by Mike - PA on November 19, 2008 at 12:14:34:
Everything is clean in the tank, line & screen. Have good gas flow from the line. Replaced all manifold and carb gaskets. Good vacuum. Also engine has good compression everywhere, around 125psi. Did not check the carb drain. Something I didn't check, there is a small "screw" in the bowl of the carb. Was told this was the idle valve? I never had this out. Would that cause the motor not to start at all?
