Not sure which parts you need. My 2606 has a auxillary cannister filter that came with the IH 3000 loader mounted in the loader frame. Changed it over a week ago and dropped it on the ground. Wasn't sure what parts went where then.
A flat aluminum appeared to go on the inside of the cannister on the bolt. Then the small hole of the filter which has a rubber washer on it. Then the large end of the filter at the open end of the cannister had a plate recessed a few inches. I put the pyramid shaped spring with the small end on the filter and the large end seemed to want to fit the filter base. Tightened it up and no leakee. I thought the flat filter going against the cone shape of the cannister would cause it to leak there because the filter doesn't seem like it would go flush against the aluminum washer. I did figure out the spring can't go on the inside of the cannister first before the filter.
I'll let the others chime in here but I wonder if you can get by without the washer and spring.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
