Re: F30 oil pressure slow???
Posted by Janicholson on November 19, 2008 at 19:03:32 from (66.173.50.78):
In Reply to: F30 oil pressure slow??? posted by Alex Jeremy on November 19, 2008 at 18:48:48:
Some fittings will squeeze the tiny pressure tube to the point that it just passes a tiny trickle of fluid to make the gauge go upward. When you shut it off when the engine is cold, does the gauge drop slowly? if so this may be it. Air in the line also causes this to happen. JimN
