Re: Torque values using a socket extension
Posted by RustyFarmall on November 20, 2008 at 05:29:03 from (209.152.78.9):
In Reply to: Torque values using a socket extension posted by Dr. Bert on November 19, 2008 at 20:15:40:
Bert, in theory, you are correct. If that extension did not have some "flex" or twist desingned into it, the extension would most likely just snap when you applied torque to it, so yes, the use of an extension will effect torque values, and in some applications it might actually be critical, but in the real world of torqueing down the head bolts or manifold bolts on an old farm tractor, the use of an extension is nothing to be overly concerned about.
