Re: Torque values using a socket extension
Posted by IaGary on November 20, 2008 at 05:49:45 from (207.177.17.200):
In Reply to: Torque values using a socket extension posted by Dr. Bert on November 19, 2008 at 20:15:40:
Here is my thinking.
If you are putting 100 ft lbs to the drive end of the extension, the other end of the extension is putting out 100 ft lbs also.
If it starts flexing at 90 foot lbs it is still putting out 100 if that is what you are putting to it.
It is not geared up or down so the energy put into it has to come out the same.
Look at it this way you put a tire between two chains to pull a 10,000 tractor.
If you set the pulling tractor to pull extactly 10,000 lbs it will pull the tractor.
10,000 lbs into the tire and 10,000 lbs out if the tractor moves.
The tire will stretch but still pulls 10,000 pounds.
Gary
