Re: Napa coils didn't work! M Farmall
Posted by TheDurk on November 20, 2008 at 09:27:19 from (72.76.180.25):
In Reply to: Napa coils didn't work! M Farmall posted by Mike Farmer on November 18, 2008 at 20:19:52:
If I bought a coil marked 6Volt and "No External Resistor Required" I would take those two together, as in "No External Resistor Required when used on 6 volts". If used in a 12Volt circuit, it would still require an external resistor to lower the voltage to the 6 Volts it was designed for.
That said, get a VOM and check the resistance; it may have been born bad or mislabeled.
This post was edited by TheDurk at 09:35:18 11/20/08 2 times.
