Re: Carb on F-20 freezing up.
Posted by LenNH on November 20, 2008 at 14:30:58 from (24.61.134.129):
In Reply to: Re: Carb on F-20 freezing up. posted by SproutW on November 11, 2008 at 19:53:46:
Airplanes have this problem all the time. The carburetor venturi cools the air down below the freezing point and makes ice out of the moisture in the fuel/air mix. There is always some kind of heat diverter (from the manifold, I think) called "carb heat." Pilots turn on the heat when they slow down the engine, or if they sense that the engine is losing power.
Make a shield of some sort around your manifold and carb? Don't know if the heat would flow down, but it shouldn't take much to keep it from icing up.
