Re: M flooding
Posted by Janicholson on November 20, 2008 at 17:22:40 from (66.173.50.136):
In Reply to: M flooding posted by grant nelson on November 20, 2008 at 16:44:53:
If you are choking it, try having the choke on for just the first cylinder crankover, then opening the choke all the way.
If you leave your fuel valve on when it is not being used, shut it off (even for a 15 minute break) this keeps fuel from entering the carb through a slightly worn needle and seat, and is to be considered Standard Operating Procedure.
If the engine runs normally when it does start, I suspect the worn needle and seat.
The rubber tube should not leak anything. A leak will pull in dirt, Not good.
An air cleaner with heavy oil (should be engine oil) or one with water freezing in it, will also cause the flooding. JimN
