Re: Torque values using a socket extension
Posted by Janicholson on November 20, 2008 at 17:59:47 from (66.173.50.136):
In Reply to: Re: Torque values using a socket extension posted by Dellbertt on November 20, 2008 at 15:27:19:
For a balloon to float (in air) the balloon must be filled with something lighter than air. Helium, hydrogen, are two common gasses that will work.
The pressure in the balloon is just modestly above atmospheric (to stretch the rubber). A balloon filled with air falls to the ground. A tank of compressed air indeed weighs more than a air tank with a open fitting balancing internal and external pressure.
0.076lb per Cubic foot for 60 degree air at sea
level.
0.456lb per cubic foot for 60 degree air at 75psi
(Rock Excavation Handbook)
JimN
