Re: M flooding
Posted by CNKS on November 20, 2008 at 18:13:17 from (216.144.104.128):
In Reply to: M flooding posted by grant nelson on November 20, 2008 at 16:44:53:
Jim is correct, but that is pretty severe flooding. I suggest replacing the needle and seat, while you are at it you might as well do a complete carb rebuild ( disassemble, soak in carb cleaner and install kit). Most of my carbs leak some, but the hole in the bottom of the carb takes care of the drainage. I do shut off the valve when not in use. IH carbs typically flood when started with too much choke, they run a few revs, die, and won't start afterward.
