Re: Farmall A H4 Magneto problem
Posted by winds1sj on November 20, 2008 at 19:39:39 from (209.206.135.90):
In Reply to: Farmall A H4 Magneto problem posted by winds1sj on November 19, 2008 at 08:43:02:
Hi,
I replaced the coil with no change. So, I looked at the cap and rotor again and found that the new rotor was bent down just a little bit from the manufacturer. Bent it up a little and I have blue spark. Thanks for the help.
winds1sj
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
